Home › Forums › Products › Rackmount › H9000 Stereo Looper? › Reply To: H9000 Stereo Looper?
Hi! How the looper sync to tempo? Is it rock solid? I ask because sometime with MIDI Beat Clock, a sample loop can drift if its not retrig… Did H9000 use something to lock to protocol if I use the Pro tool expansion card? Thanks!
Hi Thierry,
The looper algorithm (or any time based effect) can be synced to either the H9000’s internal tempo, an external MIDI clock, or your DAW using “Tempo Mode”. I’m not sure if this answers your MIDI Beat Clock drifting concern, but when using Tempo Mode with the looper algorithm it will be locked it to your DAW’s tempo. A Pro Tools expansion card isn’t necessary for this, the expansion card allows you to connect the H9000 to a Pro Tools HD interface via DigiLink.
