Home Forums Products Rackmount Orville: PCMCIA Card Reader adapter for Compact Flash Reply To: Orville: PCMCIA Card Reader adapter for Compact Flash
#156994
    You need to be sure that it is an SRAM card. A lot of the bigger ones you mention are probably ATA flash, which will not work.
    The biggest card that Orville supports is 4M but these are rare and expensive; 128-512K are much more common.
    All these will be quite old by now, so you should put in a new battery before you try and use them. (Except for rechargeable cards).
