Home Forums Products Rackmount H9000 – mono sum dry signal path in summed algorithm? Reply To: H9000 – mono sum dry signal path in summed algorithm?
#157034
    joeydego wrote:
    If I wanted to get my DAW sessions tempo to the H9000, is there a way to do this using only the connected Ethernet cable? I’m currently getting it to my fractal via USB, but I’m not connected USB currently to the H9000.
    Yes, you just need to set TEMPO MODE to DAW and your H9000 will be synced with your DAW. This will only work when you're using Emote as a plug-in in your DAW, it won't work in standalone mode.
