Home Forums Products Rackmount Midi and H9000 Reply To: Midi and H9000
#157093
    joeydego wrote:
    So I’m not finding the section in the manual regarding midi mapping. I see when I right click on a parameter I get the mapping pane to pop out. I hit learn and it maps itself to something on the controller I move. This is working. I’m finding knobs and faders to be unusably choppy, like they go from one to 100 with nothing in between. Surely I’m doing something wrong? I didn’t sync anything with the korg control software yet to make assignments. Just plugging it in out of the box.
    I think the issue here is with the nanoKONTROL2. It needs to be in "CC mode" to work correctly (I also had this issue the first time I tried it.)
    Hold the set and cycle buttons on the controller as you plug it in and then it will be in CC mode and should map correctly. You only need to do this once and it will stay in that mode until you change it.
    Let me know if that works.
