Reply To: H9000 & Latency Correction in Cubase
Home Forums Products Rackmount H9000 & Latency Correction in Cubase Reply To: H9000 & Latency Correction in Cubase
#157218
wvought
John Baylies wrote:
What happens when you click the ‘ping’ button mentioned in the video? https://www.youtube.com/watch?t=189&v=H-N-9AGlrXk&feature=youtu.be
Things look a bit different in Cubase 11 than they did in that video. The ping function is a larger button that reads Measure Delay. When I click it, it turns white for about 1 second, but after this the delay reading does not change. It still says 0.00ms.
My guess is that this means I am not actually getting a signal into and back out of the H9000, but I followed Ondo’s directions.
My understanding is that this method completely bypasses TotalMix. The signal flow is Cubase out to ADAT > H9000 > ADAT > Cubase. So IOW it doesn’t matter what my TotalMix settings are….Cubase has assumed control of the designated ADAT ports, and TotalMix plays no part in the process. So I don’t understand why signal would not be going through the H9000.
