Home › Forums › Products › Rackmount › H9000 & Latency Correction in Cubase › Reply To: H9000 & Latency Correction in Cubase
#157224
joeydego
    Also even if for nothing other than exercise in the interest of learning, it’s probably a good idea to learn how to set up a midi device. Sooner or later, you’ll come across something you’ll want to use that needs to be set up. This too was an issue I had that I needed to learn.
