Home Forums Products Rackmount Infinite Sustainer Algo for guitar – Not compression based Reply To: Infinite Sustainer Algo for guitar – Not compression based
#157399
    There is currently no freeze/sustainer Eventide algorithm, but I have mentioned your request for one to the developers.
    You could try some of the H9 delay algorithms (9101-9109) that include the "repeat" on/off switch in the "config" settings. If you set a short delay time and engage the switch while a note is playing you can get a similar infinite sustained sound, but with varying results. You might like this option as an alternative to the reverb freeze sound.
