Home Forums Products Rackmount Eve/Net not working with two units Reply To: Eve/Net not working with two units
#157434
sprawl
    thank you for getting back to me.
    I just got it to work. laugh
    I tried the Eve/Net without a fuse in any unit and obviously it did not work.
    I also tried a 2A fuse without luck. That one blew as well.
    So basically we tested everything except that cheap T adapter!
    I bought three of them because why not. They were cheap. One of them i openend up to check the connections. Another one i used to connect the remote with the two Orvilles.
    I was under the impression they were identical. They are not. One of them is bad. I just tried the third one and it works! There must be a short in the other one.
    I should have checked that earlier…
    Thanks a lot for your help.
