Home › Forums › Products › Rackmount › Coming from H7600 to H9000 › Reply To: Coming from H7600 to H9000
April 17, 2021 at 12:31 am
#157667
jerzythepeddler wrote:
Well, I just got my H9000. I’m trying to get everything setup and had a question. Does the unit work out of the box like a standard a/d/a converter. For example can I simply plug in an analog signal into the db25 channel 1 and it will come out the adat digital channel 1? Or do I have to manually route it to work this way?
Thanks,
Josh
Save your sanity and read the Emote manual and use that. All the I/O is drag and drop. Really simple once you wrap your head around it.
