Home Forums Products Rackmount H8000FW – Factory Only testing duration Reply To: H8000FW – Factory Only testing duration
#157769
    The tests run continuously until you stop them. T= gives the number of tests performed. If E= is greater then 0, that is a failure.
    Don't run any flash or CF card tests more than a few hundred times, as these parts can only accept a finite number of write cycles.
    Does sound like you may have a flash memory fault.
