Home Forums Products Rackmount ganging controls in the H9000 environment Reply To: ganging controls in the H9000 environment
#157912
joecozzi
    If you have the H9000, when you click on the PARAMETERS button, and then click on the FUNCTIONS soft button in the bottom right, you’ll be able to see all the Function knobs that correspond to that FX Chain. If you select a Function knob and press the check mark button, you’ll be able to see all the mappable parameters from all the corresponding algorithms in the chain if you scroll with the jog wheel. On Emote, you simply navigate to another algorithm in the chain and do the right click process to assign a parameter to the same Function knob.
