Home › Forums › Products › Rackmount › /persistent failed re:(problem solved) › Reply To: /persistent failed re:(problem solved)
        July 6, 2021 at 12:54 pm
        #158195
Sorry to hear about your issue and the confusion with the Factory Reset startup sequence.
There is an issue with the H9000R Factory Reset startup sequence and that is why it wouldn't work for you. Connecting to your H9000R in recovery mode and selecting the reinitialize option performs the same function, so I've updated the user manual to follow those steps instead. Let me know if you have any other issues.
-Tyler
