Home › Forums › Products › Rackmount › /persistent failed re:(problem solved) › Reply To: /persistent failed re:(problem solved)
July 18, 2021 at 1:57 pm
#158250
Skorefish wrote:
Don’t push the network button when using the paperclip method.
Make sure your h9000r and your computer are in the same network range. Network card in dhcp automatic mode?
Thanks for the help. Still not sure why nothing is happening, as my H9000R is connected via ethernet to my PC which has internet access. I will have to put in a ticket again.
Thanks again
