Home Forums Products Rackmount Why can’t you delete the last module in an FX chain? Reply To: Why can’t you delete the last module in an FX chain?
#158289
    This is just how the UI is configured; there will always be at least one FX chain and each FX chain will always have at least one algorithm.
    If you'd like a blank slate, you can load the FX chain "1601 TEMPLATE – DEFAULT." You could also simply replace the last algorithm in the FX chain with a "Thru" algorithm, or any algorithm of your choice.
