Home Forums Products Rackmount H9000, Morphing between presets… Reply To: H9000, Morphing between presets…
#158438
J20056
    Ron,
    All my expression pedals are used externally to a DAW, either to control cross fade volumes of the Swtichblade, or to control H9000 FX parameters.
    I am not sure in what context I would that for a DAW, but if you mean recording automation of certain channel volumes or else in a DAW, I suppose it is doable. I usually record fade automation from my control surface so I don’t know how to do it from an expression pedal but I assume it’s easy enough depending on interface.
