Home Forums Products Rackmount Emote plug-in crashes Logic Pro 10.6.3 when H9000 finishes booting Reply To: Emote plug-in crashes Logic Pro 10.6.3 when H9000 finishes booting
#158480
    Hi David,
    I wasn't able to reproduce this issue, although I am running Logic 10.6.2 and Big Sur.
    When I create a new project in Logic and add an instance of Emote, I am able to power cycle the H9k and connect to Emote multiple times without Logic crashing. I can try reproducing this on another system but your best option may be opening Logic after everything is powered up if that solution works for you.
    -Tyler
