Emote plug-in crashes Logic Pro 10.6.3 when H9000 finishes booting
Home Forums Products Rackmount Emote plug-in crashes Logic Pro 10.6.3 when H9000 finishes booting
    • #116632
      ddv
      I discovered that if I have a project (even a new project with just one audio track) with an Emote plug-in instance, when the H9000 finishes booting, Emote will crash. I’m running Logic Pro X 10.6.3 on MacOS X 10.15.7. I’m using Ethernet on both the Mac and H9000.
      Generally I power everything on before I fire up Logic, now I know it’s best to stick with that approach 🙂
      I have a couple of crash dump outputs if you’d like me to email support please let me know.
      Thanks,
      David
    • #158480
      Hi David,
      I wasn't able to reproduce this issue, although I am running Logic 10.6.2 and Big Sur.
      When I create a new project in Logic and add an instance of Emote, I am able to power cycle the H9k and connect to Emote multiple times without Logic crashing. I can try reproducing this on another system but your best option may be opening Logic after everything is powered up if that solution works for you.
      -Tyler
