Home Forums Products Rackmount H3500 Midinam File Reply To: H3500 Midinam File
#159647
noodle1
    Without having H3000 in front of me, I think you use ID mode on H3000 rather than regular map mode… (sends out number of 0-9 and also 0-99 to make a program change)
    “When using the “ID” program change method, programs with numbers greater than 127 can be accessed by changing the bank number.
    To change the bank, press {Bank=0} and turn the knob. When the bank number is set to 0, programs 0 through 99 will be loaded with program change numbers 0 through 99. If the bank is set to 1, programs 100-199 will be loaded. If it is set to 2, programs 200-299 will be loaded, etc.
    There are a couple of special cases:
    For program change numbers 100-127, the bank number is ignored (programs 100-127 always loaded).
    To load last edit, set bank to 10 and send any PC 0-99.”
    N.B. In order to set Program Changes to respond to bank select, enter “MIDI Program Load Functions” [press FUNCTION button 4 times]
    set the options ( Map ) ( Pgm=ID ) ( Pgm=On ) (Bank=0)
