Home Forums Products Rackmount #1416 Four Filters – only filter #1 works on H9000 Reply To: #1416 Four Filters – only filter #1 works on H9000
#161306
J20056
    Got it. I thought they were in series from the same I/O. Ok, I can easily send the mono input “in parallel” to each of the 4 inputs, and sum the output. I think that would work for filters as I think parallel summed would be equivalent to serial in this case, since I only plan to do low pass + high pass filters, do you agree?Thanks
