Home Forums Products Rackmount #1416 Four Filters – only filter #1 works on H9000 Reply To: #1416 Four Filters – only filter #1 works on H9000
#161313
    Ok, glad that helped.
    Hard to say if the series vs parallel routing for the filters will give you the same result. You can try 2 instances of the alg routed in series with low pass on one of them and high pass on the other, and compare that to 1 instance of the alg summed together with combined low/high pass filters and see if it works for you.
