Home › Forums › Products › Rackmount › Emote losing connection › Reply To: Emote losing connection
        February 18, 2022 at 2:28 pm
        #162299
If you are referring to the “Device disconnected unexpectedly” pop-up message, this is a bug with certain OS versions (including Big Sur) where Emote will disconnect when out of focus, and we are looking into this. In the meantime, if you use Emote as a plug-in, you shouldn’t experience these disconnections. Or, you can simply reconnect while using the standalone app, and you should not lose your connection while you are actively using Emote. Sorry for the inconvenience.
