Home › Forums › Products › Rackmount › Dante connection issues › Reply To: Dante connection issues
Thanks for the videos. It looks like the clocking is correct when the H9000 is the leader and the Galaxy is the Follower. I’m not sure why audio isn’t making it into the H9000 when the H9000 is following the Galaxy. Regardless, you’ll have to make some adjustments to that FX Chain in Emote.
In video1, at 1:14, when you disconnect those connections, the meters respond correctly. Those meters show the levels of the FX chain routing blocks, not the Group routing blocks. If you would like to view the levels of the Group routing blocks, use Emote’s Meter Bridge, which is accessible in its menubar under Window. I will have to clarify that in this chapter of the manual.
The FX Chain in video1 at 1:14 is routing audio from Dante in 1/2 to Analog out 1/2. Those analog outs are the XLR outs on the back of the H9000. Try the routing in the image below:
