Home › Forums › Products › Rackmount › Dante connection issues › Reply To: Dante connection issues
February 21, 2022 at 3:33 pm
#162347
When the meters run like that while no audio is playing it indicates clock sync issues.
I’d double check the Ethernet cables next. They’re all less than 100m and >Cat5, correct? Are all your Dante devices plugged into one router, or do you have a more complicated setup?
You may also try increasing the Device Latency
here:
edit: you posted while I was typing! best of luck with the new switch!
