Home › Forums › Products › Rackmount › Ultratap Ultraswell in h9000 – CHOP bug? › Reply To: Ultratap Ultraswell in h9000 – CHOP bug?
#162645
    Yes, I am referring to the IN GAIN parameter. It’s up to you if you want to always map the gain to return to 0 when bypassed with your configuration. When I am using this, the gain increase is not making that noticeable of a difference. If the higher signal is an issue for you, you can decrease the output of your FX Chain. Or you can set UltraTap’s IN GAIN to +6 and OUT GAIN to -6, and this should balance things out without additional mapping.
