Home › Forums › Products › Rackmount › H9000 USB FX chain in Logic › Reply To: H9000 USB FX chain in Logic
#163842
    If you’re still experiencing issues with this, I would suggest loading the “901 Reverb Buses” factory session. This will ensure that all of your routing on the H9000 will be correct, and any audio being sent to the H9000 over the USB channels 1-16 will be processed by a reverb.
    Another simply way to troubleshoot your routing is to load the algorithm “13 Note Oscillator”. This will put out a constant sine wave tone, and can help you determine if your H9000’s outputs are routed correctly to your DAW.
