Home Forums Products Plug-Ins Anthology Xii Licenses showing up in iLok License Manager but not DAW Reply To: Anthology Xii Licenses showing up in iLok License Manager but not DAW
#163956
    Hi Evan,
    Sorry for the issue you’re having. Please see below and let me know what happens:
    1. Confirm you have the latest version of your plug-in installed: https://www.eventideaudio.com/products/plugins
    2. Confirm that you have the latest version of iLok License Manager installed.
    3. If you already have iLok License Manager installed, open iLok License Manager and select iLok License Manager → Check For Application Updates in the toolbar. If you do not have iLok License Manager installed, download the installer at http://www.ilok.com and install. Make sure the plug-in license is activated to your machine or iLok dongle in the iLok License Manager.
    4. If steps 1-3 don’t solve your issue, close your DAW and uninstall the plugins.
    – Newer plug-ins have an uninstaller is located at /Applications/Eventide/Uninstallers.
    – For older plug-ins without an uninstaller, delete the following files:
    AAX: Mac HD/Library/Application Support/Avid/Audio/Plug-ins/Eventide/<plugin name>.aaxplugin
    VST: Mac HD/Library/Audio/Plug-ins/VST/Eventide/<plugin name>.vst
    AU: Mac HD/Library/Audio/Plug-ins/Components/<plugin name>.component
    Presets and Docs: ~/Music/Eventide/<Plugin Name>/ (whole folder)
    5. Open your DAW and rescan your plug-ins, and then shut your DAW again.
    6. Deactivate and reactivate the plug-in license in iLok License Manager.
    7. Reinstall your plug-in.
    8. Reopen your DAW and rescan your plug-ins.
    9. AudioUnit only: If still not showing, some macOSes occasionally require a restart for Audio plugins to correctly scan.
