Home › Forums › Products › Rackmount › H3500 Midinam File › Reply To: H3500 Midinam File
August 1, 2022 at 6:00 pm
#164873
There is also a LSB/MSB 14-bit style midi method parameter change version of bank select, using system defined parameter number […] parameter 8197 value 0 to 10 (0 thru 9 is first digit of H3000 program #, 10 is last edit)
will send the details later, will be almost identical to this post, but on 8197, instead of 8196:
CC#0 didn’t get added until later units, as far as i can tell
