Reply To: Eclipse: CCs
Home Forums Products Rackmount Eclipse: CCs Reply To: Eclipse: CCs
#165060
noodle1
Are you creating an arpeggio using 4 different pitches, and then sequencing them with their individual delay times?
I see how that gets annoying!
You need to get yourself something with the SEQUENCER module, which can then be programmed so as to be adjusted quickly from the front panel of the Eventide, similar to Harpeggiator, but better options that you create yourself.
It will be more difficult to program the structure (Need Vsig, and program LFO, sequencer, pitch modules, etc), but will be far superior to “hacking” an eclipse…
I have some extra 7000s if you need something with Vsig and can’t afford other options.
In this situation eclipse would be great for the backend/reverb simple functions.
Cheers
