Home › Forums › Products › Rackmount › H9000 – Radio compress › Reply To: H9000 – Radio compress
September 26, 2022 at 3:16 am
#165785
That preset comes from the DSP4000 days. The Compressor module has a known bug causing that crackle. It was never fixed. Compressor 2 was added, which doesn’t have artifacts and is a little heavier in DSP resources. If you use Vsig it would be worth changing the module and things will be ok.
