Home › Forums › Products › Stompboxes › Harpeggiator is so close to greatness › Reply To: Harpeggiator is so close to greatness
#165907
    This feature request has been around since the PitchFactor.  I wouldn’t hold out much hope for an update now [Max is maxed out].  I too had some hope for custom scales with the release of H9 Control, but I understand why it wasn’t incorporated.  Backward compatibility, hardware limitations, probably a lot more involved than pointing to fixed sets of LUTs, etc.
    Best you can do is dig deep into mixing & matching the Rhythms with Dynamics, pitch sequences & FX, in order to carve out some ‘new’ patterns.  If you’re running mono, a set of two Rhythms blend into a third type.  With stereo, panning combinations.  I can give you a few ideas to try out at this link:
    https://www.eventideaudio.com/forums/topic/seq-view-50-harpeggiator-presets/
