Home Forums Products Rackmount Is the Mission SP-H9 expression pedal compatible with H9000? Reply To: Is the Mission SP-H9 expression pedal compatible with H9000?
#166024
formants
    I am wanted to use a Roland EV-5 Food Pedal with my H9000. Also this pedal (I was trying out other typs too) seems to have “calibration problems” I wasn`t using any pedal until now because I never got it running but now I think I give it another try.
    The problem is that the values around 0 and 100 are not translated smoothly. So sometimes I have a value 4 when my pedal ist closed.
    It does not matter if I change direction of the pedal ( closed means open and open means closed)
    It would be nice to have padels that work without jumps in their values and really reüresent 0 to 100.
    The Link from the post above does not work anymore…
    Thank u for you attention!
    Philipp
