Home Forums Products Rackmount Eurorack CV to H9000 Reply To: Eurorack CV to H9000
#166695
chuckhague
    Re: befaco cv thing, I’m seeing HiRES MIDI as a menu option in the firmware code. Can you confirm whether you have that enabled / disabled? Perhaps toggling that off will fix the issue.
    I’m not skilled enough with github stuff to know about that, unfortunately. I have found that running CV through a sample & hold makes things work better although it’s not an ideal solution. I’ll definitely be interested to hear if you can get it working that way.
    IIRC, the workaround is to map MIDI to the Emote plugin’s Functions, which will then send the function data over your LAN, which won’t choke the H9000. Like this: Screenshot 2022-11-14 at 2.05.43 PM Not like this: Screenshot 2022-11-14 at 2.07.53 PM
    Thanks for the info! I’m hoping to find a workaround that allows me to bypass the computer, but I’ll try this if I can’t find another way.
