Reply To: Several issues I’ve found along the way
Home Forums Products Rackmount Several issues I’ve found along the way Reply To: Several issues I’ve found along the way
#169038
alexone
So we can remove many interesting algorithms from the list. Because in the workflow, either you have projects with different sample rates (and with the H9000 and windows, changing sample rates is hell) or you forget these algorithms. Either it’s a bug, or you can’t use the H9000 as it’s supposed to be used. But this is not a missing feature.
