Home › Forums › Products › Rackmount › H9000 Thru preset question › Reply To: H9000 Thru preset question
March 6, 2023 at 9:25 am
#169579
Yes, joeydego is correct here.
Keep in mind that any algorithm in the FX Chain will introduce a small amount of latency. Any time I use a Thru algorithm it’s usually to troubleshoot my routing and make sure audio is passing.
If you’d like to route your input to your outputs with no effects processing, you can use Direct I/O routing – https://cdn.eventideaudio.com/manuals/h9000/2.0/content/emote/views/directIO_view.html
Direct I/O routing allows you to use your H9000 as a digital patchbay while still have access to all 4 FX Chains.
