Home Forums Products Rackmount LFOs for h9000? Reply To: LFOs for h9000?
#169580
    With the tools you have, you could simply draw your LFOs as automation in Pro Tools and map those to a Function in Emote, then whatever H9000 parameters are mapped to the Function will be automated. Not quite the same as a constantly running LFO, but if you loop a section of your Pro Tools transport it can accomplish the same thing. This video demonstrates something similar – https://www.adsrsounds.com/kontakt-tutorials/use-pro-tools-automation-to-control-any-kontakt-parameter/
    It looks like this plug-in can also generate MIDI CC data and apparently works with Pro Tools, I have not tried it: https://xferrecords.com/products/lfo-tool
    Agreed that internal LFO modulation would be great, and I’ve noted your request. This is not something we’ll be able to add soon so I’d suggest finding an alternative method for the time being.
