Home › Forums › Products › Rackmount › H9000: Master volume control in Emote › Reply To: H9000: Master volume control in Emote
March 21, 2023 at 1:20 pm
#169847
For your use case, are you always using a reverb (or another “wet” effect) in parallel with your dry signal? If so, you can turn Kill Dry on, and the Algorithm’s mix control becomes a “wet” level; turning this to 0 will result in no reverb output. Currently, only the H9 algorithms offer kill dry, but we are looking into adding this as a general parameter for all algorithms.
