Home › Forums › Products › Rackmount › 96k with Dante? › Reply To: 96k with Dante?
April 20, 2023 at 10:08 pm
#170567
I loaded a default session that just has thru routing and the H9000 doesn’t change to 96k. Should I be expecting the H9K to automatically switch to 96k when I start a PT session at that sample rate? or am I missing a setting somewhere? In Dante controller, I’m getting the Red Cross out stamp on all IO, and if I hover it says sample rate mismatch. PT session and focusrite are all running just fine though at 96k. Clock is set to Dante in H9K prefs and set to Internal (Dante) in the focusrite prefs. Thanks for your help!
