Home Forums Products Rackmount Solved Boss FV-500L dual expression pedal insert cable wiring with H9000 Reply To: Solved Boss FV-500L dual expression pedal insert cable wiring with H9000
#170587
J20056
    Apologies, the above in incorrect. The correct method is to wire both TRS connectors (replacing the TS) to the Tip of such connectors. The original TRS of the split cable is unchanged, resulting in a Tip-Ring and Ring-Ring effective split wiring. This 100% works.
