Home › Forums › Products › Rackmount › Is the Mission SP-H9 expression pedal compatible with H9000? › Reply To: Is the Mission SP-H9 expression pedal compatible with H9000?
May 6, 2023 at 7:17 am
#171058
I’ve just repaired the link in the above comment. I will test out your issue with an EV-5 pedal and get back to you.
I am also facing the same problem. Is there any way to solve it?
