Home Forums Products Rackmount H9000 Session Save Feature Request Reply To: H9000 Session Save Feature Request
#173934
    Thanks for this request. Yes, I agree that the saving procedure would be improved with what you describe above.
    Do you have an H9000 with a front panel? If you use the saving procedure on the front panel, it will update the Session name and use the current Session name when you save again. You can use this in the meantime for a better saving procedure.
    I believe the issue is just when you use Emote for saving, and we’ll look into improving that.
