Home › Forums › Products › Rackmount › H9K Algo Request › Reply To: H9K Algo Request
#175714
jbamberg
    It is our plan to release the DSP modules for H9000/Vsig users when we’re ready to do so.  Sometimes we won’t release them immediately, generally because we want to make sure they are reasonably straightforward to understand, i.e. they have a simple interface and sufficient documentation.
    For RNBO, you are obviously free to share your patcher with other users who have Max/RNBO.  However, you can’t export a RNBO algorithm from the H9000 into Vsig, because the RNBO system doesn’t use the Eventide DSP modules, it uses the Cycling ’74 RNBO objects instead.  You can export the compiled algorithm from emote as a .9ka file, and share that with other H9000 users.
