Home › Forums › Products › Rackmount › H90 preset libraries for H9000 › Reply To: H90 preset libraries for H9000
I’d love for this feature, or for the H9000 having the ability to import and export H90 and H9 presets.
I’ve had a look at the file structure (for the H9, though I imagine H90 would be similar). Theoretically I could build a tool to convert between them, except I can’t get my head around how the checksum is implemented by Eventide (ie what is included in it, such as headers and data, data only, is it sorted in a particular order, and how the checksum is calculated, because often the check sum is a negative number, which it shouldn’t be). It may be a type conversion, but that makes it difficult to test.
The H9 preset seems to be embedded within the H9000 presets, so exporting to H9 will probably be easier than importing from H9, but it would be so much better if this could be done on the unit itself or from within emote.
