Home Forums Products Rackmount Display/Enter values of min and max parameters in MAPPING Reply To: Display/Enter values of min and max parameters in MAPPING
#176180
    Yes, this is something that we hope to fix in Emote so it correctly displays the min/max values when mapping a parameter.
    Do you have a unit with the front panel? If you go to Parameters > Custom Map the min/max values will be displayed on the H9000’s screen. The would be the best workaround for mapping precise values.
