Home Forums Products Rackmount h9k failed to connect to emote Reply To: h9k failed to connect to emote
#181691
    The H9000 has a setting to use either ethernet or Wi-Fi as the network source. If the connection is working for you with ethernet, that means the setting on the H9000 is expecting an ethernet connection, and the Wi-Fi adapter will not work. You’ll need to change this setting to be Wi-Fi for this to work properly, it’s not clear if you have tried this.
    Are you using an H9000 or an H9000R?
    In my last message I gave you details about how to change the network settings on the H9000, please confirm you are changing the network setting to the appropriate source when you are using ethernet or Wi-Fi.
