Home Forums Products Rackmount When Is the Next Update coming? Reply To: When Is the Next Update coming?
#183550
virtuoso
    Good to hear that 96Khz compatibility is coming at last!
    I would love to see the following, ideally before I die. These are mostly based on (vague) promises from Eventide going back several years, so I don’t think they’re either unreasonable or unrealistic:-
    – Ability to set Favorites and filter accordingly
    – Dual patch presets from the H90
    – Ability to chain more than 4 algorithms
    – DAW mode for fixed latency (yes, there’s a workaround but it would be nice to see it implemented properly)
    – New H9000 algorithms!
    (From the FAQ) – Are there any new algorithms on the H9000?
    “New FUTURE algorithms is the main reason we created the H9000. The decision to migrate from fixed point DSP to ARM was, in large part, driven by our conclusion that creating new ways to effect sound will be more efficient using the tools available for general purpose processors. The ARM platform also makes porting our plug-ins to the H9000 more efficient.”
    Re: Chaining more than 4 algorithms
    Nov 2019 – “In the nearer term, we are planning to add the ability to connect between DSPs in the next release, so you’ll be able to connect up to 16 effects without tying up analog IO and patchbay connections. This is supported natively in the system, but we don’t have a UI for it just yet.”
    Oct 2020 – “I think that ideally, we’d figure out a way to extend the current model so you could have 8 algorithms in an FX chain instead of 4, without restrictions on how they are laid out.”
    March 2021 – “Sorry but this won’t be something that will make it to the next H9k firmware release. It is still something that is being discussed and a feature that we’d like to include in a future release. Thanks for your patience.”
    Re: DAW Mode for latency
    – July 2021 “I can’t promise a date for when this will be ready, but adding this feature is a high priority. Thanks for your patience.”
