Home Forums Products Rackmount When Is the Next Update coming? Reply To: When Is the Next Update coming?
#184579
    Can you elaborate when you say “numbering imported algorithms”? When you import an algorithm, an Algorithm ID (ie. 10101) will be automatically generated. When you use a tool such as VSig or RNBO, you can customize the number when you compile/export the algorithm. Are you requesting to change this ID number or something else?
