Home Forums Products Rackmount H8000A – “Faulty presets code installed” Reply To: H8000A – “Faulty presets code installed”
#184686
Jules123
    I`ve exactly the same problem with my H8000FW, did you find a solution or a way to reimport the presets?
    I first had an E12 error, then changed the battery and did a factory reset (holding down 8 during startup) with no success.
    Then I performed the self test (holding down 5, test all) which may have been the main mistake and probably have erased the factory presets.
    Then I removed and cleaned all socketed ICs, including U106 which showed reaction during wiggling (contacts were quite oxidized). I now know I should have done this first…
    Finally I successfully installed firmware 5.61 but now got the message “faulty presets code installed, contact factory”.
