Home Forums Products Rackmount Does H9000 run hot? Can it be sandwiched between other gear in a rack? Reply To: Does H9000 run hot? Can it be sandwiched between other gear in a rack?
#184820
Matthias Adloff
    The fan keeps being loud. Very loud, not only because of air flow but also because of a small ,yet noticeable amount of rattling and vibrating. I do not see any difference when toggling the fan control in Emote. Booting from cold in a cool environment (~10° Celsius) the fan spins up to its maximum speed and remains there, regardless of what I set in Emote.
    Any way to read out the internal temperature? A faulty thermal sensor? I mean, I could just add a resistor to the fan, but I do not want to destroy myH9000R.
