Home Forums Products Rackmount Does H9000 run hot? Can it be sandwiched between other gear in a rack? Reply To: Does H9000 run hot? Can it be sandwiched between other gear in a rack?
#184824
    Can you please email support@eventideaudio.com with a video that demonstrates the noise you are hearing? Can you also toggle the fan speeds during this video? It should be noticeable that the fan speed is changing when you toggle this setting.
