Home › Forums › Products › Rackmount › H8000A – “Faulty presets code installed” › Reply To: H8000A – “Faulty presets code installed”
#184921
Fender17
    I guess, you may reflash the firmware and load new presets. But those things may be tricky. If your does not work anyway, why not to try? Or find somebody experienced nearby who would do it. Not much to loose.  If it fails you will have to send it get repaired. And if you do not try to fix it, you will have to send it get repaired.
